renjaminfrankln
I have not seen any decent pictures of this on any of the write-ups I read. Currently the pump is out of my truck and I have turned the engine over a bit to get the lobe in the right spot.
First pic is of the lobe hanging down. You want this lobe to be up and out of the way when installing the new pump. 2nd pic is after I rotated the engine by jumping the starter solenoid. You can no longer see the lobe hanging down. This is the
Can anyone confirm that I have this right? If so, let me know, and feel free to add these pics to a write up in the tech section.
Also, does anyone know off hand the fittings needed to convert the mechanical pump to fuel filter line to a regular fuel hose (barbs, thread sizes). Or a source for a new hard line. My hard line was so corroded to the brass fitting that it just twisted right off with the brass fitting.
