Bronco tank conversion questions..
VandalS
California
Ya now Russ, with way less sulfer perhaps your onto something...and being that many here use WMO/WVO it's quite possible that it won't affect anything actually
It is the sulfur that reacts so if you use road-diesel you should be fine. If you use tractor diesel you will probably end up corroding your tanks and sending crap through the pumps and injectors.
