Bronco IDI conversion
NTOLERANCE
I'm the cotton swab
cottage grove, wi
Anyone ever done one?
I am thinking about looking for one, and converting to an IDI. I'd prefer a Zf 5speed, 3.50 gears and I'd like to keep the 1/2 ton axles. Not looking for a serious off road rig or anything like that, just a nice 19mpg diesel full size suv.
Any thoughts?
rjjp
Needs to go test
Clare, Mi
I read somewhere that Ford did it to, they made three of them to test the TTB suspension, I do believe that i read it on here.
I been workin on it for several years....*****....hope this year...thought it would be last year....but I am working on a bad A#$ build with 1ton running gear and big lift, so kinda takes while.
88beast
pa
ya its easy youll need a donor truck though
you need the motor mount plates from the donor they bolt in with 2 bolts per side and the other 2 will need driller out then wiring is easy you can leave efi stuff but youll get a check engine light is all
