commonsthor
whats best brake upgrade i can do to truck in sig?? slotted rotors better calipers ect. thanx
towcat said:"jaybee" is running a factory E350 rear axle off a '99 e-series. Those haven't went to metric yet. Most of the after market disc kits won't let you use DRW due to rim interference. If you do go for a factory dics changeover, make sur eyou are buying one that has the e-brake on the axle not on the back of the trans like a F450. Do-able but pricey since you will need a 4X4 trans for the ebrake unit to bolt onto. the ebrake unit is pricey too. $900(street value) for a rebuilt. On the booster side, I pulled the hydroboost off a F450 chassis I have and mounted it onto my F350. literally a drop-in. Lotsa WHOA with the hydro but you still will have fade on the drums.
