ah1988ford
Brake pedal is hard but brakes dont grab until 2-3sec after you push it.
I just got done replacing a wheel cylinder and a spring kit on the rear pasengers side brake. I made sure the drum had a bit of drag befor I put the tires back on. I bled that wheel until there was no air in the fluid, go in the truck engaged the parking brake then dis engaged it ( to center the pads). Then I drove the truck in reverse and hit the brakes. The pedal was and it hard, I put steady pressure on it and it takes a couple of seconds befoore the brakes actually grab the brakes are soft they dont grab hard.. I did not bleed all of the wheels and the rabs distributor thing under the cab, i am extremely tired and taking a break. Should I go ahead and bleed all the lines ?
Or is there something elses wrong that I am missing ?
