Brake Pedal Flies to the Floor
7.3IH_Eggrole
Corn Shucker
NC
Replaced the master cylinder and everything seems to be good. As a matter of fact the brakes are better than I can ever remember them being. Bench bled them then bled everything starting from closest and worked my way further from the MC. I did end up putting a new NAPA 1.25" MC that was suppose to be for a 1996 F350 on it. The part number was NMC M3379.
Here is a link to the part:
http://napaonline.com/Catalog/CatalogItemDetail.aspx?R=NMAM3379_0358751541
The only modification I had to make was pluging the 3/8"-24 port.
Thanks again for all the support and knowledge.
Thank you for the update, it's allways good to read the results and learn things, thanks for the link too
tke395
