Kevin 007
Full-floater
Ok so the other day in my 95 F350, DRW, 7.3, the brakes started to sink to the floor when the truck was running, as I was trying to maintain a steady hold on a hill, waiting for a traffic light. No leaks in system, including the wheel cylinders, so I assumed that that master cylinder was bad, being original. So I replace it along with the original front calipers. I bench bled the master by plugging the outlet ports and pumped till the bubbles stopped in the reservoir. As I was gravity bleeding the entire system for a couple hours, I adjusted the rear brakes until I got some drag when spinning the wheels. I then started bleeding the RR on its own, into a jar at first and then holding the pedal down and cracking the bleeder, moved to the LR, then the RABS, then FR, the FL and then I cracked each fitting at the master cylinder while having the pedal held down, just for good measure. I have done this 4 times now, gone through 3 quarts of DOT 3. I pump the pedal probably 10 times before cracking any line. Im not seeing any air escaping from anywhere, just solid fluid.
And my pedal still sinks, worse then before. If I make a hard application quickly, it will hold hard for a second or 2, then start sinking. This is with the truck running, and with it off (no vacuum); it holds and doesn't go down, so the new master should be good right?
Any thoughts?
Any thoughts?
