brake ignorance question
psy9zach
keego harbor michigan
not sure where to start this question but my truck was originally a 460 gas auto 2wd, its now a 6.9idi it has a mount with a old proportioning valve on it thats bypassed with it going straight to a splitter to the drums, i know the 6.9 usually uses RABS and ive converted to hydroboost but would putting a proportioning valve in the truck get me more pressure to the front? im about to be replace all of brake lines(blew a line between front and read not sure if its related) and would like to get it to behave somewhat normally ive never had a vehicle with working abs so to me its not a loss not having it. just curious bc i saw another post where someone said our master cylinder(the old iron ones) have a built in proportioning valve but if it has one it sure dont look it to me but ive been wrong before and this is what it looks like
Macrobb
North Idaho
I think the proportioning valve was only used on earlier models, to reduce the amount applied to the rear brakes when unloaded(to prevent locking up the rear tires). My 88s and later(with rear ABS) do not have the valve.
If you reinstalled it, you could probably get it to do what it was designed to do - prevent the rear tires from locking when unloaded, and have full force to them when loaded - but I've never worked with one myself. Looks simple enough though.
Randy Bush
Great Falls, Mt
All of my trucks have this valve . 89-90-93 dually. It screws into the master cyl.
Macrobb
North Idaho
That's not a proportioning valve, it's a residual pressure valve - basically, drum brakes need to have a little pressure even when your foot is off the pedal, so they don't collapse too far. Disc brakes don't need any pressure. So, a disc-drum setup will have a residual pressure valve on the drum side.
Randy Bush
Great Falls, Mt
That may be , but it is still listed as a proportioning valve. Isn't the job of the brake adjuster to keep them from collapsing to far.
Don't worry about not having the ABS, that system is difficult to keep working and most people bypass it. The factory proportioning valves on the older trucks are starting to fail also with rust in the fluid. If I were worried about it, I would buy one of these adjustable valves and put it in the line to the rear. You could mount it beside the seat if you wanted to adjust it on the fly.
https://www.speedwaymotors.com/Speedway-Purple-Adjustable-Brake-Proportioning-Valve,23498.html
Wheelsrollin
