res0wc18
Hello i have a problem. i have a 1990 dodge cummins 4x4 auto(727). This drive train setup is going into a 1986 ford f350 4x4 that has a 460/c6/np208
Problem 1: Need a drivers side drop transfer case that will bolt up to the 727.First that comes to mind is nv241.
Problem 2: I want to use a np205 but the dodge and ford 205's are way different. So i though swap out the input shaft to the ford unit. well that would make the shaft way to long. and they use a wierd adapter. See where i am going with this?
Problem 3: speedometer issues. how would i make it work correctly when swapping out the cases?
here is the info site for all needs.
http://www.high-impact.net/transmission_and_gear/Tcase_NP205.htm
