ormgott
Bought a Facet Dura-lift pump for my '86 F-250 with '92-1/2 7.3 NA IDI. It was running fine after I bought it, then just didn't want to start. I've installed a Schrader valve in place of the ball valve the PO had installed. I get fuel out of the valve when cranking, but I believe someone said there should be some pressure after you stop cranking? Definitely don't have that and it takes a short cranking to get the fuel. I can also get fuel at input to IP, but don't seem to get it at the injectors. Hate to run the starter and batteries excessively, so that's why I'm going with the Facet pump. After reading a few posts, I'm wondering if it's going to be producing too high pressure. If so, is there an easy way to install a pressure regulator, say on the filter input or output? If so, does anyone have a specific part number?
Seachoice 20331 Dura-Lift Electronic Fuel Pump, Solid State Construction, 120 Inches Lift, 11.5-9 PSI, 33 GPH
