boost numbers
jbelcher0628
marengo, ohio
hey you first geners i was just wanting to know what kind of psi you guys are pushin thru the turbo and what you have dun to it..i got a 93 cummins 275 k miles, it has a grounded fuel pin and pod injectors and i am pushin 30 psi. i was really surprised by this number, and just was wondering what others got? thanks
Whit
lost in Why-homing
thats about what ya should have for yer setup
get ya a HX 35 turbo off a 98.5-2002 manual tranny truck and ya can get more air and at 32-34 psi
rebel_horseman
Rt. Wing Extremist
West Florida Republic
30 sounds about right with minor pump mods and PODs. Those are pretty much the numbers I've been reading. I haven't installed my gauges yet (that I bought a year and a half ago) since I've been moving. Hopefully in a few months I can tell you what I'm putting out.
averagef250
Portland, OR
The H1C on a 93 has about the same compressor as an HX35. The HX35 has a restrictive 12CM turbine housing. If I was in your shoes with a 93 dodge and stock turbo I'd dump the huge exhaust housing and go to an aftermarket 14 or buy a cheap 16CM from a 4BT H1C and bolt it on.
The H1C's are cheap, good turbos.
LucasPower
B.C.
Mine is is pushin 32psi...40 if I crank the screw up and change the depth of the pin. Wich ive only done once.
