Boost Gauge Pegged Today
Needed to drive the rig a little harder than what I usually do and watched the bost gauge climbing nicely. Was just under 10 lbs and wondered what it would stop boosting at. So I added more skinny peddle and watched it peg the 15 lb gauge and tried to go even further up in pressure... :eek::angel: Now I wonder if my boost gauge is telling me the truth. I have never been able to peg 15 lbs with any Moose pumps yet. Truck did seem to me running on 2 more cylinders instead of the usual 8 cylinders...:angel::angel::angel::D
jhenegh
Truck Still Earns its Keep
Deerfield, WI
Mine will do better than my 15psi gauge too. Still smoking too if its below 3k rpm LOL. I DO NOT make a habit of this. Stock-ish E4OD ai't gonna hold that for too long. Even studded, if I can't get it moving with 12psi and keep it moving with 5-8, it's too heavy or I need to shift ;Sweet
Clb
Another old truck
nannyfornia
The 88 with a junoir would hit 15 and blaze the egt's easy.
I bet a comparo of different pyro's with different thermocouples swapped around would be interesting.
Even same setups as supplies from maker on same truck.
FarmerFrank
Blairsville, Pa
Just when I was happy that my truck hit 14 with stock head bolts and a messed up compressor wheel. But when it's 10*F outside it sure will cram the air in.
tke395
