Bolt Pattern Swap
Beave32
Beave32
Nampa, Idaho
what would be the bolt pattern for my 8 lug 1988 F350...would it swap with a 1984 Chevy 3/4 ton?
Clydesdale
Nampa,Id
Yes, all 8 lugs are the same til you start looking at wheels from a StupidDuty.
then they are slightly different.
That truck has stacks on it now, a stack anyway, huh?
the bolt pattern is the same but the hub opening is different. ford uses the largest of the three makes as far as hub openings goes.
Bo17
