69dieselfreak
well that nice
i like it....
thank you sir
i like it....
Has anybody put a crankcase evac system like they use on drag race cars?? I had one on my mustang and it worked like a charm on oil leaks. I know these diesels have alot more blowby but if you were not worried about keeping the oil and the exhaust made enough vacume to draw out any positive pressure in the crankcase that would be great. But would there be any problem with having a negative pressure in your crankcase if the vacume off of the exhaust was too much??
The Warden;3219 BTW said:1'' clear hose from home depot
id run some thing flexable because of engine torque
hard line will break
my drain is just 1/4'' dot air line should be fine we'll see
it wont run away im helping to enviromentI like the design. I've made catch can setups before, that will work nicely. You will need a one way valve on that oil return though or the pressure from the lower crankcase will push oil up through the tube ( can you say runaway
