The several I have done I sealed with just the oring. I did make sure that the sealing surface was cleaned up well with no nicks. Orings are great at sealing themselves in general if they don't get damaged.
Follow up question. Does this look like the right block heater?
I have messed with it for 30 minutes now and I see no possible way to insert this thing. There is not enough movement in the toggle part to let it slip in. It's like the bolt holding the toggle doo dad is too short.
The ears on the bit that tightens to the block look huge compared to the OEM part, which is more like a traditional toggle bolt. Maybe trim them down to diameter of block hole+.3"??
Well, given its a 3 year ago eBay purchase, best case is I can make it work. Worst case is I have 2 brand new heaters with new cords or as the case may be 2 brand new heater cords. [emoji849]
