bigger tires=better gas mileage?
Can30Diesel
Agassiz BC
Another small piece of the puzzle is weight, steel rims are heavy. I moved to Aluminum rims and I noticed a little difference in response with my truck. I'm singing the 410 3000rpm blues too, but I can tow pretty much anything and thats what the truck is for.
Wicked97
Nebraska
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
235/85-16 7.9in 15.9in 31.7in 99.7in 636 0.0%
285/75-16 8.4in 16.4in 32.8in 103.1in 614 3.5%
i really cant say that would be a lot of difference, being the height of the 285/75r16 is only 1.1 inches taller, cause you would still divide that by 2 to get the height gain on the truck.
It was 150 rpm so I guess its not that much. Been a couple years. I went from a 31.2 inch tire to a 33.1 inch tire and probably added 40 lbs a wheel.
bagpiperjosh
Windber,PA
If you put larger tires on around town you will inhale fuel and realistically, most folks spend a LOT more time on side streets than they realize It ends up taking a whole lot more fuel to get all that extra rolling mass in motion, and a lot more brake power to get it stopped THink of larger tires as adding 4 extra heavy flywheels. Yes they are great at storing energy once you get them going, but it takes a lot to get there and then once you get all that energy stored in them, it takes a bunch of energy to counteract the energy stored in them to get them to stop.
If you try to tow with larger tires you will really take a hit. BEst bet is to add an overdrive or Brownie. I have the best of all worlds, a full deep reduction range, stock range and over drive range ( double OD) with the ability to split all gears.. With a 4.10 rear I went from a best 14 mpg ( usually worse ) to 18-20 empty , and over 11 towing HEAVY ( better depending on the trailer )
what is a brownie?
FORDF250HDXLT
Maine & Oklahoma
larger tires won't be doing your wallet any favors lol.
for those revving with the old school direct drive transmissions......it's time to upgrade.the fuel savings $ for a good deal on a used zf5 could just be refunded @ the pump inside just a few oil changes......after that,it's pure savings.
im 1350-1400 ish rpms @ 45 mph in OD.
bagpiperjosh
Windber,PA
So when people say " put in an od" they mean do to a zf5 swap? Theres no way to "add a gear" to a trans? Sorry ifthats a stupid question
dgr
sac town
They could be talking about a 5 speed or an actual 2 or 3 speed auxiliary transmission like a ranger or gear vendors or brownie.
RLDSL
Diesel fuel abuser
Arkansas
what is a brownie?
A 2, 3 or 4 speed auxilliary transmission , pulled from an old either semi truck or large mid range dump etc. you wind up with an extrshifter to fool with ( just like the old big trucks with twin sticks )
They do not have synchros so they do take a bit more skill to drive. I have a 3 speed 5831b Spicer in mine giving me a 5x4 arrangement , or 15 forward and 3 reverse gears :D
bagpiperjosh
Windber,PA
that sounds like a nightmare to install
PwrSmoke
Northwest Ohio
RLDSL is right. Overall a five speed or an overdrive (or a 5-speed AND an overdrive) with 4.10s is the best combo of performance and mileage. If you can afford it.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
My '84 book ('83 should have used the same codes) shows a Dana open axle, 3.07 gears, and 6250 lbs capacity. IITC that should be a semi-floating Dana 60...do you have hubs/axleshaft end caps sticking out from the brake drum a few inches?
The semi-floating Dana 60 is a rare bird especially behind a diesel (it's more of a light-duty F-250 thing), but I've seen a couple on '83 and '84 trucks, so I can say with authority that they do exist...even though most semi-floating axles are 5-lugs and found on half-tons.
Full-floating axle:
Semi-floating axle:
bagpiperjosh
Windber,PA
Full-floating axle:
Semi-floating axle:
links not working for me
FordGuy100
Silverton, OR
I'll keep rocking my T-19!
Bigger tires wont help fuel mileage. Taller tires should in theory help at highway speeds. If they made a 255/85/16 A/T style tread it would be the best choice.
