big block bronco
Tow Beast
Tow beast
anacoco,la
i have an 89 bronco it has a 79 460BB ,8 inch superlift w/ 40's ,full msd ignition, just wondering if anybody is into the mudding thing and if u have suggestions
Tow Beast
Tow beast
anacoco,la
pic to follow
Brimmstone
Makes me miss mine. It's sitting in Ohio waiting for me to come get it.
82F100SWB
Sioux Lookout, Ontario,CA
Hmm, suggestions... rebuild the 460 with some compression, 79 is 8.0:1 or less. A very mild build with some portwork and around the 9.5:1 compression mark will make very impressive power.
1 tons, Boggers, spool/weld the rear.
Good solid tow points front and rear, besides the winch, you want some nice solid clevis mounting points.
I will make no suggestions towards gearing, 5.38's will put you to the equivalent of 3.55's and 31's, but, you engine is what really makes the call on that one.
I'm currently running 4.10's with 44's, and a close ratio 6.9 T19 with the 4.02:1 first gear, sounds like an undrivable combination, but, my engine is built for big dumb low end torque, and in low range, it actually works very well.
http://www.youtube.com/watch?v=qlO9Roo21_E
Thats second gear, which is only 2.4...
Vincent
