Best antifreeze?
rreegg
IDI n TDI
Puget Sound
I haven’t personally but folks around the forum have mentioned using it with good results.
divemaster5734
Olympia, Washington
Thanks Everyone for your responses.
Decided to go with the Peak in concentrate for the best price.
$20.09 a gallon, $1.40 gallon of distilled water = $21.55 every two gallons, and no need for the $20 additive.
Jim993
Prescott, Arizona
Most diesel owners don't understand the need for routine coolant maintenance. In my view, cavitation is an old wives myth. Velocities in the cooling system are not high enough to cause true cavitation. What actually happens is that the true cause of corrosion of the block, oil cooler and older steel head gaskets is caused by the coolant becoming acidic. Diesel engine compression and brake mean effective pressure is so high that over time, CO2 molecules get by the head gasket into the coolant. Water plus CO2 forms carbonic acid and if the coolant is not treated to raise PH, internal cooling surfaces of the engine will corrode. Long haul diesel fleet operators have known this for a long time and monitor coolant chemistry, adding supplemental coolant treatment when needed. Here is good, inexpensive source of coolant test strips.
Phoenix Systems 8006-B Double-Ended Brake Fluid + Coolant Test Strips (15 foil wrapped test strips), 1 Pack​
About $15.
Amazon's Choice
1K+ bought in past month
abcdefg
