Bed/Brake Light wire location
Bill-W
GA
Does anyone know where the wire harness for the bed light on my 88 ext cab runs down into the cab?
I picked up a brake /bed light combo from a c4c truck a few weeks back at the junkyard for a few bucks and got it cut in and mounted but now I need to wire in the brake light signal. I just don't feel like tearing my whole inside out looking for it. I guess I should have looked at one in the junkyard before I left, oops.
I was going to wire it off the signal to my brake controller as I have the factory pigtail wired into the controller and I figured it would be an easy please to get the signal from without the flasher signals.
Here's some pictures of the new one installed:
Any help / advice would be greatly appreciated.
If your truck has it, it's going to be in the wiring running under the driver's side sill plate on top of the rocker. It will be a lightgreen wire. The wires for the domelight, map lights, and seatbelt warning switches run in there as well.
