The truck has finally been starting consistently enough to get an inspection and drive it to work yesterday. No issues on the way, but when I got to work, I turned the key off but nothing shut off. I killed the motor at the FSS but realized with all the accessories still on, I'd have a dead truck by the time I got out of work. Had no tools to unhook the batteries so I jumped in to drive it home where I had tools. I started it back up, then tried shutting it off again and it worked. So I went into work. Drove it home and it shut off there without any apparent issue. Next morning batteries are dead.
Either it wasn't shut off all the way, or in the night it made a connection. I'm not sure which is more probable.
Is the ignition switch out of adjustment or is the actuator totally hosed? How do I make sure the truck is completely off without disconnecting the batteries?
Tim.
Tim.
