Banks turbo install question
JPR
Fort Worth, Texas
The first question, I am sure more will follow.
On the E4OD, do you have to drain transmission before swapping the dip stick tube? The instructions don't mention draining it and I would rather not unless necessary, but at the same time I don't need an oily surprise.
apextrans
What Log Book????
Fallston, MD
I just installed my Banks Kit about a month ago. I have a C-6 & didn't drain the tranny. Just unbloted the old one, popped it out & put the new one in. Simple as that. Good luck with the install.
apextrans
What Log Book????
Fallston, MD
Any time. If ya have other questions, free free to ask. The install is still pretty fresh in my mind.
aaklingler
Winfield, PA
I would guess you don't have to, i don't think oil comes out of the tranny and the dip stick comes apart about 4" above where it goes into the tranny.
JPR
Fort Worth, Texas
I missed that when I first looked at it. I did get it swapped out yesterday. Got to the point of bending the body seam and loosely bolting in the "turbine inlet casting". However, I am missing the one of the turbine inlet casting braces and missed placed the new glow plug heat shield. I will be calling Banks.
Not sure if I bent the lip enough or not, but at this point if I need more I will be buying hockey pucks and new body to frame bolts next week.
