fields_mj
I've always noticed that I have a little bit of play on my drive shaft. When it's sitting in the drive turned off, I can rotate it just a little bit back and forth. Maybe 1/8". Well, this winter I had the gears swapped out, and put in a different 3rd member to match. The guy who did the work has always done good work on my wifes car, and he builds race trucks in his free time (that would be between the hours of 10:00 PM and midnight from what I can tell). I spoke with him, and it sounded like he had done the gears on quite a few of the trucks and hot rods in the area. Anyway, he called during the repair to get the okay to replace some additional bearings in the rear that he was concerned about. All good. Well, I get about 3/4 of a load of firewood in the back last week, and I noticed that after I back up, when I put her back in 1st gear there is a noticeable CLANK. It sounded like what I used to hear on my 2wd F150 when the U-Joints were totally shot. I got home and got the wood off, and then checked the drive shaft again. I could rotate the drive shaft noticeably more than what I used to be able to. But I don't see any play in the U-Joints. It looks more like there's play in the splines between the tranny, the drive shaft, and the diff. When I'm empty, I have to stand on it a little to hear the noise, but it's still there.
Any suggestions on what this could be? I'm getting a little worried that something important and expensive is going out on me.
Thanks,
Mark
Thanks,
Mark
