I think BTS has some. Off the top of my head, I can't remember the other couple companies.
Imo, it's a light duty trans.I’ve seen so many zf5’s with bearing noise and gear issues behind na diesels.
Well I can only disagree with you there. My zf5 has over 250k on it and has never been open, I guarantee your e40d doesn’t have that kinda record. I’ve had three running e40ds for sale at core price for months and haven’t gotten a single hit, zf5s I sell the same week I receive them. I have what I like and you have what you like no sense in argueing about this anymoreI know it’s hard to grasp but the e4od with a semi built hard parts and good converter will be much stronger than a zf5, I’ve seen so many zf5’s with bearing noise and gear issues behind na diesels. But the e4od and 4r100 is well proven at the strip, off road, and sled pulling. Don’t get me wrong the zf5 is a good trans but not in the same ballpark as a well setup e4od
Well I
To the op though, if you don't find any lights loose or blown, you could try the lockup switch, and see if it still misbehaves. If you run it in manual ovveride and it still locks, you know the problem is not your fipl at least
Interesting that it was the cause. When mine went, it just wouldn't go past second gear.....glad it took care of your problem
What's this,another E40D thread hijacked by manual shifting ZF5 guys?......So surprising.
They (FIPL/TPS) should be replaced every 50k miles anyway,because they ware.
Tell me how many of the 17,000 + members that have an IDI with so much HP and Torque that an E4OD can't handle even without modifications, talking about a well maintained one. Did any of you ZF guys check your Left leg measurements against your Right leg.![]()
