work that looks like thatso what do you get when you cross and Asian and a redneck?
go down to home dept and do the PVC hose mod. that will tell you plenty on air bubble issues. switches aren't cheap. fuel pumps will have a constant stream of air bubbles and air in the return side will do a drainback when you shut the truck down.So, I readjusted the fuel pick up. I started it back up and brought it up to 2500 or so. It ran for less than 20 seconds or so, then died again. I pulled the fuel filter and it was almost empty. I am charging the batteries, then will switch tanks to see if it also happens on the rear tank. If it does, then I am suspecting the lift pump, or a clogged line. If it does not, then I am suspecting a bad switch or plugged line.
Any thoughts?
lmk a day in advance so I can get a scooter from SJ for the photos op.****, I really wish I could, but have family stuff and my daughter had a double header at 6!!!!! Thank you though.....might have to make a tactical trip down there this week though for a follow up!
