axle swap
ironworker40
NYC Ironworker
nj
Okay just spent an hour looking but can't find anything so if there is a post on this let me know were it is.
axle swap 1988 f-250hd regular cab 400 gasser c-6 4.10 traction locker. Will this go in a 1993 f 350 diesel crew cab 7.3 zf-5 ? I know with is right but are spring perches going to be at the correct angle? Are these dana or sterling rears? what about u joint size?
Also will transfer case from a 250 c-6 bolt to a 350zf-5? bolyh are 1356 bw
FarmerFrank
Blairsville, Pa
Yes, and yes.
The axels are both sterling and will be a direct swap. If the u joints are different then swap the yokes. Being a 93 rear it should be a short yoke like the 88.
On the transfer case that depends if the are both fixed yoke or both slip yoke outputs
NO_SPRK
User & Abuser
Santa Rosa, Ca
88 has a abs sensor which is also used for 92+ speed sensor
Sent from my SCH-I605 using Tapatalk
NO_SPRK
User & Abuser
Santa Rosa, Ca
Yes, and yes.
I think Fixed yokes are found on only broncos
Transfercase will work, but you need to swap yokes.
250 vs 350 use different u-joint size.
It'll be slip yoke on the rear.
Sent from my USCC-C6721 using Tapatalk
NO_SPRK
User & Abuser
Santa Rosa, Ca
Yes front yoke will need to be changed. Nylock nut too. Just impact it off
ironworker40
NYC Ironworker
nj
So my 1993 uses abs sensor in the rear axle for the spedo ? That brings up another issue, my abs light is on. Any tip on troubleshooting that? Abs isn't working I can lock up the rears.
