ats turbo setup
greg_a_morton
blossom tx
Im getting a Idea from you guys as to if any body would want to buy a full ats turbo setup off a running 6.9? I would be buying the truck for gauges and some other small parts. The truck is a 87-88 model beat up badly 6.9 5speed with ac. Let me know if there is interest in this because these dont seem to come around every day.
greg
6 Nebraska IDIs
What kit is it? Wastegated or non? I wouldnt be interested in buying it, just trying to clarify for others that I know are interested. Also, probably wouldnt be a bad idea to just decide now what you'll want for the setup, people dont like getting their hopes up about stuff only to find out later that the seller wants an outrageous price for it.
h2odrx
Anti-O
Coastal Neckville, NC
greg
What ya need for it?:dunno
greg_a_morton
blossom tx
I would be giving $1200 for truck. Thats the reason I was wondering If any body would need more off the truck so I would not have to sell the turbo kit for so much. If I buy the truck and all I sell off of it is the turbo then I would have to sell the kit for atleast $600-$700 then the rest would be scrape after I pull the gauges and little stuff I want. Let me know If this is a reasonable price for the kit. I did not look under the airfilter box to see what the turbo looks like but the seller says it gos down the road good with no smoke. I will probable look at truck better tomorrow if I can.
6 Nebraska IDIs
is it an F250 or 350? You wont have a problem getting a couple hundred for that 5spd either, especially if its a 4x4 one with the transfer case.
Is it a single cab? I REALLY need a ZF5 driveshaft, but I'd bet shipping would kill me outta the deal.
6 Nebraska IDIs
dang, 2wd. I would need a single piece drive shaft. it wont work with my truck. I'll probably just have to have mine cut.
greg_a_morton
blossom tx
the truck sitting next to the one Im buying is a 3/4ton diesel extended cab of same years if that drive shaft is any different.
greg_a_morton
blossom tx
Im going to buy truck and I will list items on sale forum when I get tore apart. thanks for everyones time. greg;Sweet
greg_a_morton
blossom tx
got truck home and got pump and injectors off and am working on getting the turbo off. I had questions over which turbo it is. It appears to be a non wastegated turbo and is rather small. the down pipe is tight against bodyline and it looks to be atleast 3" or bigger. This was surprising when I cranked up the truck and drove 70mph all the way home, usually when you buy a beater they dont drive like this one. The truck had a few nice gauges and a pyro gauge that is mounted right after the turbo on the ats downpipe contraption.
This was by far the best running 6.9 I ever have drove and I guess the turbo makes a majority of the diffrence. Also got a added plus of about 17gallons of farm diesel out of the tank!
RLDSL
Diesel fuel abuser
Arkansas
Too bad it's not a newer model, I could use a few body parts for my '92 and I'll be driving right past you in a few weeks to go see my sister.
