Not a good idea
Ive been there and done that.
I installed a used Ats kit on my 93 and was in the same boat.
I was all excited an had to start it and run to make sure there was no leaks the all the sudden I had oil running down the down pipe .
I called a turbo rebuilder the next day thinking thet the turbo was ruined or???
They said check for excess crankcase pressure, check the valve.
I then proceeded to tell him that I didnt hook it up yet.
He said thats the problem that the turbo works on pressure and with the crankcase pressure high it is pushing oil up the drain and out the exhaust.
So make sure you hook it up.
I want to the parts store and bought a preformed hose and a gromet to match on the ID.
I think it was 1" to run off the valve and make a 90 degree bend then used pvc 90 an put a stud of pipe out of each end.
Put one stub in the hose going to the valve and the other end I held to the valve cover and marked the spot. I was shooting for the flat spot on the valve cover.
Then took off the valve cover, drilled the hole, installed the gromet and put it back together.
Good Luck
John
