Whit
ATCO Tilt deck trailer
30' bed tripple axle gooseneck ,Rated capacity 26k lbs.
This trailer needs new tires a wooden deck and some wiring but the frame is in solid condition .
The wheels and tires are 16.5's....I have included some more pics to help clear some things up
I had a tandem duelly beavertail that didnt work as well as this tilt deck.....pull 4 pins , set the trailer brake then back up...the axle subframe rolls forward and the tail of the trailer set right on the ground...easy loading then just pull forward and the axles go right to the back, install 4 pins and boom yer load down....very user friendly.........call with any questions you may have...Wyoming 307-876-2651....evenings.....Kevin
Dexter axles
16.5 tires and wheels
4500 dollars.........possible delivery
Dexter axles
