Anyone running toilet paper bypass filter ?
They are a great product.
On drivers side of block at rear there is an allen head set screw where aftermarket turbo systems often utilize for oil feed. Tying into that port would be a good spot.
All idi blocks have 4 main oil galley ports. One is top way in the back for the factory oil pressure sender or factory turbo. Banks will use the port at the drivers side bell housing flange with the allen head plug or a very small plug. then behind the oil cooler bundle. Not the filter end, but way back behind the tube bundle is 2 ports. Those are commonly used for aux oio feed to things like air compressors. If you take from any of these locations please use braided stainless steel line. The return can be good quality rubber hose. When I install my Frantz I will be returning my oil to the block off plate where the mechanical fuel pump was.
riphip
Memphis, TN.
Franz has been out a long time. Have one on my parts washer. FS2500 on my truck but it was free. Just had to plumb it.
Rick
