FrozenMerc
The difficulty level is directly proportional to how many exhaust manifold bolts break off inside the head....
Can anything help them not breaking off? Penetrant, hearing the area etc?The difficulty level is directly proportional to how many exhaust manifold bolts break off inside the head....
Nice any other tips for a smoother removal?I pulled mine with manifolds attached, then once the heads were out took them off.
During install, I left the manifolds off and put them in later.
Yes there is. You'll still end up with some coolant in the cylinders.Or pull a block plug and drain it. I guess theres one behind the starter. I didnt pull it.
Loosen all of the bolts in the intake manifold. Not just the ones that go into the head you're pulling off.Nice any other tips for a smoother removal?
Even if I'm not removing the manifolds?Yes there is. You'll still end up with some coolant in the cylinders.
Post #7......Nice any other tips for a smoother removal?
I should have said "remove" all of the bolts in the intake manifold. It will allow it to move side to side a little bit and it will let you position the head better during the install. Even if you use a cherry picker to pull and install the head, you'll be fighting the intake if you leave any bolts in it.Even if I'm not removing the manifolds?
Im tempted to do this but I may just have to wait until I can pull the entire engine and do all the preventive stuff that easily accessible then.I suggest taking the valley pan out, dont want to bend it up. Also means taking the IP out, but you're already halfway there... Just index it for timing is all.
