larson
I understand the removal and replacement of the pump itself hell its only two bolts. From my understanding i need to get the the bigger end of the lift pump cam lobe at the bottom witch in turn puts the lobe pointing up and the 1in give or take machined surface will be visible through the opening for the pump arm witch needs to be positioned under the lobe. Once that machined surface is visible is the pump arm only allowed to be installed under the lobe? I guess what I'm asking is if the pump lobe is in the right position can the pump still be installed incorrectly? If so please inform me if possible.
With all this being said I know that the mechanical pump is junk and I do plan on installing a facet e-pump just not this weekend due to general bills and such coming first in priority. So if for a month at most I can get by with this dumpster pump then that's what I'm going to do. The pump thats installed at the moment I have no idea how old it is other than its starting to leak and I'd rather fix the problem before I'm stuck on the side of the road.
as for a tip. take the alternator off and the alternator bracket. easy to do and gives you much more room to get in there and clean it all up.
