http://www.txchange.com/e4od.htm
E4OD Controllers 7.3 Diesel
Through the years there have been many updates to the controller assemblies used in Ford vehicles. None more so than the E4OD controller used in the 7.3 Diesel applications.
The most current group of updated controllers replaces the previous version which had been known to cause DTC (Diagnostic Trouble Code) #62 - Torque Converter Clutch Slippage even though all other areas of the lock-up system functioned properly.
These controllers provide much improved operating strategies that drastically improve driveability with better pressure rise control and lock-up timing over the 1993 and earlier controllers.
The following 1994 controllers will retro-fit all models 1989 to 1993. Consult this list to locate the correct controller part number for your application.
7.3 Diesel F series Econoline all 50 states use #F4TZ-12B565-AA
7.3 Diesel F series Econoline High altitude use #F4TZ-12B565-CA
7.3 Diesel Super Duty all 50 states use #F4TZ-12B565-BA
7.3 Diesel Super Duty High altitude use #F4TZ-12B565-DA
7.3 Turbo Diesel F series all states all altitudes use #F4TZ-12B565-EA
7.3 Turbo Diesel Super Duty all states all altitudes use #F4TZ-12B565-FA
