just got my report in FLUID ANALYSIS REPORT in says i have high amounts of zinc=1943,magnesium=81 theses are listed in additive metals. molybdenum= 26 is in multi source metals. iron is 246 and chromium is a 9 and these are listed in wear metals.. my viscosity is at 10.2.. about 15 tanks before my sample was taken i ran in my stock tank 4 tanks of a 50/50 mixture of wmo and diesel.. would this be the reason why im getting these high levels.. was told by amsoil these finds are from additives and treatments.. i did not use any additive in my oil but have used some in my fuel.. im using amsoil 5 w 30 in my 7.3 2003 ford. my mileage was at 116k and only 15k on this oil sample.. amsoil says to change oil at 25k .. im going to take another at 25k and send it in and see what they say..
any help on these numbers..
COMMENTS Data flagged for observation only; Cylinder region metals (pistons, rings, liners etc.) are at a MODERATE LEVEL; Bearing metal is at a MINOR LEVEL; Potassium is at a MINOR LEVEL; Potassium sources: coolant (antifreeze), lube additive or supplement, coating on new bearings, rust preventive coating, or environmental; Abrasives (silicon/dirt) are at a MINOR LEVEL; Flagged additive levels are higher than expected for the lubricant that is identified (This does not imply that the lubricant does not meet proper API, SAE or ISO classifications.);
