LCAM-01XA
'92-'94 for the IDI-powered trucks, really if you have a serpentine belt then you also got the 130-amp alternator.
Still planning on painting the housing, wasn't sure how to remove it and what color to paint it. Gloss black maybe? Dirt might show alot on that though. Maybe red![]()
Well I no longer have access to a spare 3G to take pictures of, but overall you wanna remove the VR first from the back of the alternator (four small torx sbolts), then the three long bolts on the perimeter of the alternator need removed and the rear half of the case comes off, then you can just pull the rotor out (remove the belt pulley first, lol), then if you're lucky the stator with the windings and the the rectifier soldered to it will easily come off the front half of the case but in case of corrosion it may need some persuasion before it does so, and what you're left with is the front half of the case with the bearing still in it, three bolts and a retaining plate later the bearing can be removed as well.
still not sure if I should go with black paint or what..Pulleys don't usually slip on the shaft, they get impacted on and they are a mother to remove without an impact too, have yet to see one that got loose on its own. Belt slipping on the pulley you'd have heard by now, bug time loud screamer!
and rebuild is likewise as easy? I can do that in no time, just helps to have a list of what to do. Who knows, maybe tomorrow I'll do 'er if I get my other work donestill not sure if I should go with black paint or what..
Thanks for the tip, I can snag some pictures while I do it if you want help doing a writeup
http://www.oilburners.net/forums/showthread.php?p=451695#post451695
good info but different alt.
