So I notice my alternator wasn’t charging and went to replace it today. When I took it out I noticed that 1 of the wires on the 2 wire plug was completely broken. I believe these go to the voltage regulator. I removed the connector and crimped on some spade connectors, but after installing the new alternator it is still not charging. I am thinking I may have gotten the 2 wires switched. 2 questions.
1. If I swap the 2 plug wires at the top of the alternator could I fry it, or would it just not work?
2. Which pins on the voltage regulator plug do I jump to full field the alternator to see if the voltage regulator is the issue?
Pics for reference.
Pics for reference.
