mr_smith
92 7.3 N/A
Got this truck for a steal and it had bad air intrusion. I did caps rings olives New line in the engine bay. I swapped an old style fuel filter head out as well.
I also had a new mechanical pump laying around so I threw it on. That's where my problems began.
I know very well how to make sure the lever is under the lobe.
Long story short, I went through 3 mech fuel pumps, tested before they went on the truck, but every time as soon as I installed them, they failed. I would put a known good pump in, crank it some, take it out and the pump would be bad.
I got tired of trying to figure out why so I put a cheap electric fuel pump in it. 4-7 psi 36 gph. I hooked it to the bad mech fuel pump outlet (could this be an issue besides the arm possibly breaking off?)
The issue I am having is that I am getting air at the Schrader valve.. If I hold the valve open after cranking, I will get very bubbly frothy fuel and after a second I get a solid stream of diesel. Crank again.. Same issue
When I first put the electric fuel pump on, idled fine for 10 minutes and then died when I hit the accelerator.
Any ideas on why I'm getting so much air? Besides the potential for the arm breaking off, is there anything wrong with routing the fuel through the no working mechanical pump?
I would like to avoid spending too much on this truck as I don't know the condition of the trans yet..
