Air in fuel system
IHdiesel
Warrensburg, Mo
I found a pin sized hole in the bottom of my rear fuel tank. Could that cause air to get into my fuel system? Thanks
GenLightening
Yeah, it's a CHEVY!
Pukalani, Hawaii
Only if it drained the tank and when you selected it you were drawing air and not fuel. I would check the caps and return line on the injectors and the filter head/water seperator (early style is known for causing problems).
IHdiesel
Warrensburg, Mo
Well I got the truck about a month ago, I have not used the rear tank at all and the gauge says empty. I have always used the front tank. The injectors and return lines are not leaking. The fuel filter was just replaced and nothing seems to be visibly leaking. Thanks
crispy74
