Air in fuel.....help!!!!!!!!!!!!!!!!!!!
Bray14
ft myers fl
1991 7.3 f350 please help going crazy. starts up but revs up and down on its own. Dies when you drive. Filter new, return lines and caps new, fuel line from tank new, added in line electric fuel pump. Tested line with clear going into filter and have major air bubbles. This is driving me crazy. Any help would be greatly appreciated. :hail:dunno
Well first make sure you have fuel in the tank.
Then make sure you have way over a quarter tank. Just fill er up.
Bray14
ft myers fl
Thanks but has full tank. Dropped the tank and made sure it was clean and in working condition. pick up and sock looked just fine. Thought maybe it was the pick up pump which is why we added electric pump on frame rail. So want this truck back running. It is my daughter love. any other ideas
Bray14
ft myers fl
Tried it both way with factory pick up pump and by passing it. Still same problem. I know it can only be a few things which is why this is so frustrating.
Bray14
ft myers fl
dual tank but only use the back tank. Front tank has a rust hole. Switch works fine as far as we know.
Need to bypass the selector valve. They can suck air.
Also check all the fuel line fittings.
Bray14
ft myers fl
will give it a try. so few things that can go wrong with these but holy crap this is a pain.
Bray14
ft myers fl
Going to take electric pump and run it out of a fuel can and see if it still does the same thing. That should answer if air is coming from either tank. We love our 1991 f350 dubbed "Betty White" so any help would be great appreciated.
Bray14
ft myers fl
on frame rail in the middle of cab. At the pump its is over 5lbs psi at the fuel filter it is only 3.25lbs.
That means the air is coming in before the electric pump.
But I would venture a guess as the 3.25 is inline with the mechanical pump.
MadScientist
