Definately, just replace all the parts and orings yourself, you can usually rent a vacuum pump from large equipment rental places, or if you have a good stout shop air compressor, those $20 harbour freight air powered vac pumps work nicely.
When replacing the orfice tube, get the variable orfice valve ( they sell them at NAPA, if really hot in your area get the 105 deg+ one, makes a world of diference ) also the heater bybass modification really works nice ( just did it on mine, was getting 48 deg out the duct on high recirc in mid '90's temp today , wouldn't do that before)
Before replacing a condensor or evaporator, you might want to run them by a radiator shop and have them tested for leaks, if none, flush out with AC flush , blow dry and put back in.
It wouldn't hurt to replace the hoses, but instead of buying overpriced complete hoses, find a hydralic hose shop and bring your old hoses in and have them put new rubber on your old ends, it will cost a fraction of what you would pay for new hose. If you don't have a place like that around, you can send them to the guy at
www.nostalgicairparts.com and he'll make some nice ones up cheap. Even if not on the website, chances are he has a new compressor cheaper than you'll find anywhere else too, along with all the other parts
--------Robert
