AF in Oil
lgettler
Any Where USA Presently C
Got my oil report back and they said I had Anti freeze in oil. Indicating I have a AF leak either in the Water pump or Oil cooler. Where should I start looking. What Say You? :dunno
Larry
bryand
Louisiana
I'd start with the oil cooler. Not to be the bearer of bad news could also be head gaskets??
84TD
Virginia Beach, VA
If nothing looks really off, like milky oil or oil floating in your AF, I say change your oil, put some miles on the truck and get it retested before you tear into it.
Andylad13
DieselBoy
Connecticut
but if there's anything other than oil when you drain it out, than there IS a problem. and water isnt a good lubricant. i would inspect all problem areas asap! good luck man hope its an easy fix and not head gaskets.
Seven4eight
