Got my oil report back and they said I had Anti freeze in oil. Indicating I have a AF leak either in the Water pump or Oil cooler. Where should I start looking. What Say You?
Larry
If nothing looks really off, like milky oil or oil floating in your AF, I say change your oil, put some miles on the truck and get it retested before you tear into it.
but if there's anything other than oil when you drain it out, than there IS a problem. and water isnt a good lubricant. i would inspect all problem areas asap! good luck man hope its an easy fix and not head gaskets.
