I installed mine in the factory sender location. Then, so I could keep the factory gauge operational, I installed the factory sender in the plug in the top of the water pump. I soldered an extension wire onto the factory wire. I cut the wire before the factory elbow and then soldered that onto the end of the extension wire so it still plugs onto the factory sender. The factory gauge still reads the same, for what little that's worth.
