chillman88
One of my coworkers father leaves the doors open on all his farm trucks for the same reason. Apparently it does help.
There is no reason not to run 2 cycle in the winter, assuming you add anti-gel just like you would with straight diesel.
Rock
I always use dieselkleen.
Last fill up, I put in a pint of 2 cycle oil. After about 3 miles, it started running quieter and smoother.
Hate to think what I was doing to the IP and engine without it.
At that temperature without being plugged in, you would need to have 5w oil in the engine, and probably triple cycle the GPs and giving throttle while cranking. Keep in mind, all that is useless if the batteries and starter aren't %100 and no matter what you do, without a block heater it is very ******* the engine.Discovered this morning it doesn’t work at -22 without the block heater! I must not have plugged it in all the way; when I plugged it back in it was using 1kW as it should. Got a few little pops out the tailpipe but gave up and took the minivan instead. Curious, is there an acceptable way to start when it’s this cold without external assistance? Or is the truck saying FU it’s too cold, go back inside!!
I don't know about my truck, but that's what I'd be saying at that temperature.Or is the truck saying FU it’s too cold, go back inside!!
I completely agree with this.At that temperature without being plugged in, you would need to have 5w oil in the engine, and probably triple cycle the GPs and giving throttle while cranking. Keep in mind, all that is useless if the batteries and starter aren't %100 and no matter what you do, without a block heater it is very ******* the engine.
Rock
Rock
2 years now and not a single problem with injectors. I did just have to replace my mechanical lift pump but can't say it was from the oil because it was the original pump that was 35 years old. I was never sidelined though because I have an electric pump in the system that I put there when I first got the truck that is on a toggle switch so I just flipped the switch and kept going.@KevSrFord.......that oil ratio concentration you use seems awfully thick...have you ever had problems with clogged injectors?
