'95 F-350 w/ 7.3 DIT, cranks, but no start.
fairlane_68
Ft. Sill, Oklahoma
There's no PCM communication/response with an NGS tester, PCM is getting power from good fuses and good diode, wiring from fuse block to PCM connector is good. PCM is good. When key is turned on, MIL flickers for a split second, and that's it. Wait light operates normal. What am I missing?
I've changed the PCM relay, put a reman PCM in, unplugged the EBP Sensor and the fuel heater on the fuel filter housing, I have power to and from the PCM relays (battery voltage), and at the PCM connector.
Has anyone ever heard of te MLP/TR Sensor causing a similar problem? The truck has an E4OD.
Double-S-Diesel
parts seller
derry pa
start unplugging 5 v ref sensors, cps, acc pedal, bps, map, ebp, to see if you get communication.
action4478
action4478
Michigan
Unplug the ICP , try to start it,,, you may need to get it on a scanner...IPR dc % & ICP pressure...
