94 idi turbo engine replacement
Dieseltrav
North Carolina
I am approaching replacing my engine due to burn rings and a strange knock. I bought a used engine up to valve covers and i have a solid flywheel and clutch to be installed. All accessories will be swapped, injection system, turbo, pulleys etc. I want to replace oil pan seal rear main seal water pump and freeze plugs but am looking for suggestions on things I may want to consider while it's out. Any help with part numbers on listed items is greatly appreciated. Thanks in advance!
Travis​
gfemling
North Bend, OR
Have heard that best not to mess with freeze plugs if not necessary- takes special tool and technique; don’t fix if not broken.
u2slow
bilge rat
Coastal BC
Can the rear main seal be done on its own? (providing the pan and pan seal is still good)
Reason I say is because once you have the pan off... might be wise to also assess the oil pump, and maybe pull a cap and inspect/plastigage a bearing (i.e. the thrust one).
If you are swapping or changing the oil cooler, be sure you're not also transferring a problem (or debris) from a damaged engine to a good one.
Macrobb
North Idaho
Yes; you can even do it in the vehicle with the trans removed. There's a rear plate that unbolts; at the bottom it seals to the oil pan. But you can just re-silicone it without removing the oil pan.
BrannonB
