'94 E-350 Box Truck 7.3 IDI NA
E350Floorguy
Blown HG/cavitation/cracked block or head unknown which at this point. Ex U haul truck with a brand new E4OD (<1k miles). Good batteries and new glow plugs. DRW axle and brakes in excellent shape, good tires. Interior and body are mint. No rips, tears, everything works. 17ft ALL aluminum box in very good shape, does not leak and has the ramp. Overall this truck is in excellent condition and would be an outstanding work truck if someone had the time to swap a motor. I bought it for use in my flooring business and it was working out well until I started seeing coolant in the oil. It got progressively worse until I parked it before it could hydro lock. It will fire and run but I don't recommend it. I'm looking to get $2500 for it as it sits.
royzell
Shawnigan Lake BC
Hi, where are you located ? If it doesn't sell and you part it out I may be interested in the trans and some other bits.
