im not sure how long but i will go out and check in a few minutes. and when the engines cold it will just crank and not fire at all. as far as i know the injectors and pump have not been changed. but i wouldnt think that is the problem because when it runs it runs great.
Welcome to OB, hopefully we can get you well on your way.
Take some time, READ the FAQ's as they are important for new members, it helps cover lots of things and gives you answers to questions and helps you ask informed questions. Also look at the TECH section as it does the same, lastly peruse the Hall of Shame so you keep yer hard earned dollars in yer pocket and not that of some unscrupulous vendor.
Now it goes something like this..
Just cause it runs great to you, does not mean it runs great, compared to a great running truck!
Lets look at this logically shall we.
Truck runs and starts when warmed up time and again no issue, Correct?
Truck doesn't start when cold less you feed it crack in a can.
Thus you have to me a symptom of bad glow plugs, or low compression, or air intrusion.
Pull and check the glow plugs, USE ONLY MOTORCRAFT BERU ZD9's any other ones tend to burn up more than Beru. Check glow plug relay as well and the wiring to it. There should be a large plug on the passengers inner fender with two yellow wires that tend to melt. There is an option of running a single 4gua wire in place of those silly yellow wires. Check the TECH section for info it may be there!
Get a return line kit from Mel at Conestoga Diesel or from Russ, Typ4 here both sell fantastic kits, and redo all your return lines and perhaps just to make sure your golden replace all your injector O rings and caps and new hose!
As for a Pump and Injectors, if they are original then new ones would not hurt. Again, Mel or Russ depending on which side of the continent your on!
Timing is an issue as the pump wears and injectors wear this retards timing, check out the many threads on timing, or contact Gary (Icanfixall) about his timing meter rental program to rent a meter and time your truck. I know my truck which had under 200K on it was 2 degrees off and it made a big difference when I timed it.
Please understand most here have heard or seen or personally dealt with most any issue you could come with, and collectively there isn't a better place for info on these trucks.
Again Welcome to OB
Al
