94 7.3 idi blowing white smoke at 1500 rpm with no power
Danish1965
Oregon
This is my first time on the forum. I recently purchased a 94 f350 turbo 7.3 idi. I replaced the injectors and changed the oil. Today I started the truck and it was running fine. Revved the motor and it suddenly started blowing white smoke and running rough at 1500 rpm. No coolant lost. Help????
Welcome to the forum, where did you get the injectors? Did it run fine when you first started it with the new injectors?
Jason1377
Arkansas
Mine does that some time depends on where I got got the fuel n I have new gp's injectors was replaced 60k ago before I got the truck does it on start up once many twice a week depending on where I get fuel
MICHAEL MICHAUD
North Carolina
look up timing the 7.3 idi. for the 94 turbo model you're supposed to time it to 8-9* btdc. You need special equipment to do the timing by generating an electric signal each time the #1 injector line has fuel going through it. tap into that electric signal with an inductive timing light and then check your timing with the engine running at 2000 rpms. there are good videos and posts on how to do it but the equipment is hard to come by unless you know someone with it, find some used or want to spend $300 on a new snap on pulse generator.
https://www.thedieselstop.com/forums/f30/best-static-timing-7-3-idi-178392/
Pump timing, check out the tech articles for a write up on the procedure, then look for someone near you in the timing registry that has the equipment.
rev up the motor. if the white smoke gets worse and it sounds like it's misfiring, it's the pump. it's done.
if the motor smooths out when you rev it up, it's in the injectors.
gandalf
Senior Member
CA &/or Maine
You didn't answer one of the first questions asked. Where did you get the injectors? New or rebuilt? The source matters.
Another question, does it keep blowing the smoke at higher RPMs or does it quit and act normal again? If it keeps doing this, I'm wondering if it could be sucking some water out of the fuel filter. I don't really know the chances of this being the case, but it's at least a possibility.
Danish1965
Oregon
Towcat,
That is exactly what is happening. Cant get it over 1500 rpm and misfires and will not rev.
gandalf
Senior Member
CA &/or Maine
Sorry. New injectors from oregon fuel injection in eugene, oregon.
Those should be good injectors. I've nothing but good comments about Oregon Fuel.
Before you spend any major money be sure to read "The Hall of Shame" It's in the Tech Articles or Stickies somewhere. Not all parts houses supply good products.
Towcat is very likely right about the IP. Again, Oregon Fuel.
IDIBronco86
