tonyj54
Okay, gang.
Nearing sixty non-gearhead here (wish I'd paid more attention to cars than girls, sometimes, but it ain't all bad), and have a problem with my '93 F-250.
Original problem was that, on our maiden camping trip with our 1966 truck camper, the rear wheels were wobbling badly, as if from bent axle, broken bearings, ???. I just couldn't imagine that the F-250 couldn't handle the weight of the camper(approximately 2500#'s), but there we were. So, when we got home, I unloaded camper to prepare to investigate, and parked the truck until I was ready to work on it. Next time I came out (couple of weeks, at most, not quite sure), truck would not move forward in Drive. No 'kick-down' from tranny shifting, nothing. It would drive around backwards like a champ, but wouldn't move forward.
Fast forward to few weeks ago. Got truck to move forward little by little, sometimes to circle yard, but mostly just several yards, slowly, then nothing. So, I got it far enough out that I could back it onto concrete pad to get rear end up and pull hubs to check it out. Put it up on jackstands, pulled tires. Cranked engine, put it into Reverse, expected results, hubs turn. Put it into Drive, wheels turn, just a little slower, maybe.
When I tried turning hubs by hand, wheels would turn easy in one direction, but took a crowbar to move the other way. Went to pull hubs, found left rear locked on tight. "Aha!", says I, "locked up brake." (Remember, non-gearhead here, so don't judge me too harshly just yet). Finally got hub off, proceeded to install new brake shoes, both sides. Re-install hubs and tires. Crank engine. Shift to Reverse, okay, it moves. Shift into Drive, nada.
Now, it has been a lifelong tenet of mine that you NEVER change transmission filter or flush fluid(especially at close to 300,000 miles), as everyone that I've ever hear heard tell of doing it told horror stories of the aftermath. BUT, I let myself be talked into it anyway. Pulled pan, lost two quarts or so fluid, cleaned the magnet of just dust, no large shavings. Felt encouraged. Bought new filter and gasket, put them on. Replaced fluid lost during change.
Cranked engine. Shifted to Drive. No kick-down. Nothing. Held breath, shifted to Reverse. Nothing there, either. Looked at my sweet wife, who, with tears in her eyes, simply says "I'm sorry". Me, too. Picked up tools. Get on forums, looking for answers.
Had a semi-truck repair guy come over on a few days ago with his code-reader. Looks under the hood, finds EEC connector, but his plug is different, so he can't hook up to it. Crawls under truck, looks at me and says "You don't have an electronic transmission, anyway. There's no sensors over on the right side. Only electrical connection is where Neutral Safety Switch plugs in.":***:
Okay, thought it was an E4OD. OD light on shifter knob, alternately blinks on-off, or stays lit, according to its mood, I suppose. While I was changing filter, found a metal plate that appears to have once read EAOD. Never heard of such.
HELP!! Need my truck running, for work around the farm, as well as camping.
