92 front clip swap befiore and after
Diesel_brad
Dunce
gilbert pa
W the blue interior that you have now, i would do a all blue that the cab is now(a lot less work) or maybe a two tone kinda like mine, but vise vera
Dsl_Dog_Treat
Decatur,MI
Agreed!
Not pushing the blue color as some may think, but cutting in the door jambs is time consuming to get it right, but to each their own.;Sweet
subliminal
ocala,fl
did you have to swap the core supports to the late model one? or does teh 89 support work with the 92 up stuff directly? i got a line on a front clip and i was tryimg to see if i coudl use it.
Alex S
Jeoff
New West BC
Well I was thinking about going red but i do like that two toe blue and white.
Ya i used the 92 rad support just unbolted it at the doors and body mounts and out it comes, and the cowl to. The electrical was super easy i just threw the wiring harnes on the engine and put it back in place on the new front end. Even the light socket plugs were the same. so it was a plug and play but i do have to splice in the corner lights and the horns
subliminal
ocala,fl
i guess what i was asking is , will my 89 style rad support work with the late style front end or does it have to be modified? the guy has a front clip from an f150 gasser, he says it will bolt right up but my concern is the bigger rad on the diesel.
Diesel_brad
Dunce
gilbert pa
Alex. You do have blue interior, right?
Mat J
Way down south
Jupiter, FL
turned out good, but i would have left it alone, i like the bricknose better for some reason.
94iditurbo
texas
lookin good bud! ......just remember the work/labor to re paint the door jambs and doors.
Sycostang67
Scooty Puff Junior
Kuna, ID
It's easier to swap a brick nose. If you swap an 80-86 truck then you essentially have to swap the bed out as well so the fenders match. Some people dont care, but I'm a little OCD and it would drive me nuts. I did a swap on my 85 as the bed was rusty and the front fenders were beaten.
Alex S
Jeoff
New West BC
hmmmm how well does that plastic and vinyl spray paint work for interiors, looks like it would scratch easy and look like crap
dented73
